I'm considering connecting a space heater to a relay such as this: http://www.handsontec.com/dataspecs/2Ch-relay.pdf
The goal is to control it remotely using a GSM data connection.
The relay is only rated for 250V 10A. Will this still be 10A at 110V?
The space heater's maximum setting is 1500W = 14A (@110V). What would happen if I connected it at this setting? Would it simply put out 10A = 1100W?
Is there any danger to the relay by connecting devices that draw >10A? Is there any danger to a space heater or other device from not being able to draw enough current?
