I want to know how \$ \frac{mm}{Ampere}\$ (which is the unit of current sensitivity of PMMC instruments) is defined?
i.e, How \$ mm \$ is defined in terms of \$ degrees\$ ?
For eg.:
\$ \frac{rad}{Ampere}\$ (another unit of current sensitivity of PMMC instruments) is defined as number of \$ radians \$ of deflections of PMMC (Permanent Magnet Moving Coil) instruments for \$1 \, Ampere\$ current input ,
where, \$ \quad \pi \, rad = 180^{ \circ } \$
I searched it in internet but could not find there, so please anyone help...
...... what text were you searching for? \$\endgroup\$unit of current sensitivity of PMMC instruments
....... i do not know if the results are useful to you \$\endgroup\$
