RVG sensor board
I need some help correctly identifying the U9 and U10 components on the PCB. I've tried some codebooks and I found several options.
For U9:
H1 - X6603 is a 300mA, low quiescent, high PSRR, low noise and low dropout linear regulator, but the model marked with "Lv" is a 4.7V and this board is a 3.3V
H2 - Toshiba 200 mA CMOS Low Drop-Out Regulator with Fast Load Transient Response TCR2EF series, but Pin 4 is connected to capacitor C46 and it should be NC...
For U10:
H1 - "4FD" - in the 2011 edition of the active smd components guide, it's a FT521FDa, LDO, Dual out, Vout1/Vout2=2.7V/1.8V±2%, 250mA, +CE, but again it should be 3.3V (4FJ).
Any help? Thanks.
Your U10 is a Microchip 24FC256 - spot the logo in the pin-4 corner?
I suspect that your U9 might be a Linear technology LTC1663.
The pin connections for VCC(pin-4) and GND(pin-2) are almost certainly correct, making C46 its decoupling cap.
  • \$\begingroup\$ Yes, you're right, measurements match! Thanks a lot! \$\endgroup\$
    – Alex
    Commented May 7, 2019 at 2:38
  • \$\begingroup\$ Yes, you are absolutly right, sometimes we miss out the obvious... Thank you very much for your effort and support. \$\endgroup\$
    – Alex
    Commented May 9, 2019 at 11:33
