I have a Numax DC25MF 12v lead acid battery with a quoted capacity of 95Ah (C20)
What is the continuous safe discharge current for the battery? By 'continuous' I mean a few hours without a break, and by 'safe' I mean without shortening the life of the battery.
I can't find the figure quoted anywhere (not directly anyway) and the only Numax datasheet I can find doesn't actually mention the DC25MF model.
Can I simply divide 95 by 20 and assume it'safe to discharge at 4.75 amps?
Lead acid batteries in cars do not need a CC limit but do have a CV limit as in cars. 14.2 for flooded cells.
Follow the link on the page you gave for maintenance tips.
the C20 rate is 95Ah in 20 h so a few A will last 95Ah/few A=__ h
https://www.tayna.co.uk/tutorials/caring-for-your-battery
  • \$\begingroup\$ The DC25MF is not a car battery, it's a leisure battery and it should be possible to run it for more many hours at a modest current drain (i.e. a few amps) the question is, how many amps? \$\endgroup\$ Commented Jul 9, 2019 at 12:11
