By definition, "The Ćuk converter is a type of DC/DC converter that has an output voltage magnitude that is either greater than or less than the input voltage magnitude"
So I was wondering how I can get: a) An output voltage lower than input voltage b) An output voltage higher than input voltage
Also, for a Cuk converter, is it possible to easily switch between low and high output voltage configurations, without changing the entire circuit?
