What is the difference between parallel and standard form of pid controller that is provided by pidtool in Matlab simulink? In terms of block diagram?
  • \$\begingroup\$ please read the documentation that comes with it. \$\endgroup\$ Commented Oct 27, 2019 at 8:17
The equations are slightly different and its a difference between time constants and gains.
Source: https://www.mathworks.com/help/control/ug/proportional-integral-derivative-pid-controllers.html
  • \$\begingroup\$ How will be both these different in terms of block diagram? \$\endgroup\$
    – DSP_CS
    Commented Oct 17, 2019 at 16:41
    \$\begingroup\$ @Man Ah ha, you see, that's the fun part of engineering. The block diagram is how you define to be as long as you're being consistent with your specifications. \$\endgroup\$
    – user103380
    Commented Oct 17, 2019 at 17:27
  • \$\begingroup\$ They are equivalent, only the constants change. \$\endgroup\$
    – Voltage Spike
    Commented Oct 17, 2019 at 18:21
Parallel form means controller will be connected parallel to plant and standard form means controller will be connected in series .
  • \$\begingroup\$ Please edit your question and add enough information so we can understand what you are asking. Is a plant something that grows in the ground, a manufacturing facility, etc? \$\endgroup\$
    – Gil
    Commented May 14, 2021 at 2:03
