I wanted a 16V,50A regulated power supply but could not find it in the market. I also searched for a buck converter for the same current output and could not find anything. So I thought of making it with a high current (60A) motor driver and a 45V, 20A SMPS. However, upon checking the output signal of the motor driver, I found out that it is actually a PWM signal (amplitude: 45V, frequency: 16KHz) and here lies my problem. Since I have a load which can take a maximum of 17V DC at input, connecting my motor driver directly to it is not a good idea. Now I am looking for ways to convert (or filter) this PWM output into an constant DC voltage (depending upon the duty cycle of PWM obviously!) so as to feed it into my load.
Could anyone please help me with the filter/converter design? I read about low-pass RC filters but given the amount of current that I am drawing, I will need an insanely small value of resistance with a high power dissipation capacity (about 800W) and also a very large value of capacitance (which makes it impractical.)
A rough schematic of my arrangement looks something like this:
On a side note, my load is expected to draw 40A current at 16V and I understand that I will need feedback to regulate my output voltage.
