I'm currently trying to figure out how this circuit work :enter image description here
I found this in a microchip documentation dealing with DALI (Digital Addressable Lighting Interface) protocol. The DALI protocol is mostly used to communicate with lighting equipment. I can already understand what is going on for the most part but I'm still having trouble with the function of the diode bridge. I know that diode bridge are used to convert AC to DC voltage. But in this circuit, the input is already a DC voltage, so I'm wondering what is this diode bridge doing exactly?
    \$\begingroup\$ It would be useful to link the document this was from \$\endgroup\$
    – MCG
    Commented Nov 25, 2019 at 13:26
    \$\begingroup\$ Ensures only positive polarity pulses are received. \$\endgroup\$ Commented Nov 25, 2019 at 13:31
While the DALI bus has DC power on it, the wiring topology is not polarity-sensitive. That is, either wire can go on either pin of any DALI interface connector. From the Wikipedia page:
"Each device has a bridge rectifier on its input so it is polarity-insensitive."
https://en.wikipedia.org/wiki/Digital_Addressable_Lighting_Interface#Technical_overview
  • \$\begingroup\$ Idiot-proofing a commercial system makes sense. No one actually read instructions much anymore. At least, not detailed ones. \$\endgroup\$
    – jonk
    Commented Nov 25, 2019 at 14:02
  • \$\begingroup\$ It uses the BiPhase encoding scheme to modulate data on changes rather than binary level. \$\endgroup\$
    – D.A.S.
    Commented Nov 25, 2019 at 14:17
I suspect the bridge is there to protect the circuit and keep it functioning if the DALI bus wires are reversed.
    \$\begingroup\$ From the Wikipedia article: Each device has a bridge rectifier on its input so it is polarity-insensitive. \$\endgroup\$
    – Mattman944
  • \$\begingroup\$ No it is not mainly for protection but for Common Mode Rejection with optical isolation. \$\endgroup\$
    – D.A.S.
    Commented Nov 25, 2019 at 14:58
