I can successfully burn programs using my USB connected STK600 through Eclipse/AVRDude.
From the command line, I can read fuses (using: avrdude -px128a1 -Pusb -cstk600 -v), but when I click "Read Fuses" from within AVREclipse/AVRDude I get the following error:
Programmer "stk600" could not initialize the target hardware.
Please Check that the target hardware is connected correctly
Reason:
avrdude: initialization failed, rc=-1
Is this a bug or a setup problem?
Have you tried reading the fuses in AVRStudio?
  • \$\begingroup\$ Yes -- they read just fine. \$\endgroup\$ Commented Oct 1, 2010 at 22:07
  • \$\begingroup\$ Sounds like a bug. \$\endgroup\$
    – Kortuk
    Commented Nov 10, 2010 at 16:24
