I have made a breadboard-arduino with an ATMega-328PU and the standard components taking help from Building an Arduino on a Breadboard. I interfaced the CT2102 Breakout Board with this assembly:
DTR - SCK
RXI - MOSI
TXO - MISO
RTS - Pin 1 On the ATMega
Before everything else, I downloaded ans installed the CP210x Drivers from their website. Now, it does come up on the list of "Attached USB devices" in the terminal window through the command ls /dev/cu.*
and ls /dev/tty.*
To check if everything's working correctly, I issued the "Read Fuses" command which:
avrdude -P /dev/cu.SLAB_USBtoUART -b 19200 -c avrisp -p m328p -v
I hit the reset switch on the breadboard: following what hoipolloi said on Arduino Sketch upload issue - avrdude: stk500_recv(): programmer is not responding.
No luck! avrdude failed saying:
Can anyone please help?
I tried connecting it with cu
command, it says connected. But when I try reading data off of it (fuses) with
avrdude: initialization failed.
