I pulled the preamp out of a broken guitar combo amp. The preamp has positive, negative, and ground leads for powering it at +/-25V. I would like to power the preamp with a dual channel benchtop power supply to see if it works. Is there any grounding or safety issue with plugging the DC-powered preamp into a power amp that is powered from an AC outlet?
With nothing connected to any power source, I verified that there is continuity from the preamp chassis all the way to the ground pin of the power amp's plug, so I think everything should be grounded safely. I also verified that the power supply's DC terminals are isolated. So everything seems correct, but I am still learning, so I wanted to double check before proceeding.
