I'm looking for any advice that can be given to solve this issue. I followed the design idea from here: buck regulator to CC source and it appears to work pretty well until I started raising the load resistance. 1Ω-2Ω works great, above 2Ω the current starts to fall off. enter image description here
I first thought I was running out of head room, but with a 45V input the output voltage is only reaching about 30V. I would think that the output voltage should be able to get much closer to the input voltage.
The target Vref is 0.97V for this chip, and it's doing a pretty good job of keeping that until the load resistance goes up. enter image description here
Any ideas on what to check? Thanks!
Your feedback op-amp U1 is only going to work correctly if its input voltages are between its supply rails. That is, 0 to 12 V.
If you try to push 4.5 A into a 4 ohm load, you'll have the output voltage at 18 V , so the U1 inputs will be at about \$\frac{21}{22}(18\ V)\$ and U1 will stop working correctly.
Try using a higher voltage to power U1 (which might require choosing an op-amp that allows higher voltage power supplies if you want to build this circuit in the real world).
    \$\begingroup\$ Alternatively, move to low side current sensing, if the application permits. \$\endgroup\$ Feb 26 '20 at 17:47
  • \$\begingroup\$ Replace the opamp too because you’ve majorly exceeded its absolute maximum ratings. \$\endgroup\$
    Feb 26 '20 at 17:51
  • \$\begingroup\$ @Andyaka, A simulated op-amp usually doesn't fail just from that. But they are cheap to replace. \$\endgroup\$
    – The Photon
    Feb 26 '20 at 17:51
    \$\begingroup\$ Trouble is I have a really good sim and have to download a new model each time this occurs. \$\endgroup\$
    Feb 26 '20 at 17:53
  • \$\begingroup\$ @ThePhoton I was so focused on the differential input value, I didn't consider that the common mode of the input was above the supply rail. Thanks! \$\endgroup\$
    – Aaron
    Feb 26 '20 at 17:55
