I use the following circuit to store solar energy harvested by photodiodes into a supercapacitor. The cap is rated at maximum 2.8V. The zener diode is rated at 3V, but depending on the harvested solar current it goes up to 3.15V. The schottky diode shall prevent the supercapacitor from discharging into the photodiodes.
Problem is: the voltage drop of the schottky diode is simply too low, which means in direct sunlight the capacitor gets overcharged up to 2.9V -> bad! I do not want to take a lower rated zener diode, as the current one drives the photodiodes nicely at the MPPT in sunny conditions.
Now the question: Are there any disadvantages of using a second Schottky in series, just to get another small voltage drop of around 200mV? That would be sufficient to not overcharge the supercap. But I'm unsure about other side effects. The whole circuit is extremely low power, so I want so save every possible uA.
I have seen schottkys in series, but rather for backup reasons (in case one fails).
