For my Super OSD project, I need a +3.3V supply at 250mA from a variable input of 5.5V to 20V. Cost is a concern, as is size. Originally, I considered an LM317 in a SOT-223 package, due to the small size. Unfortunately, it's difficult to get a heatsink for SOT-223 packages.
Then I did some calculations; the LM317 would be dissipating up to 4.175W with 20V input and 250mA of load and with a θJA of 140°C/W, the LM317 would cook along nicely at 584°C above ambient. So not practical.
The next solution would be a little buck converter, but I'm looking to get a small design and a cost of <$3. Does anyone know of an ideal chip for the job? Or is it still possible to use a linear regulator? I'd prefer to do so, but getting rid of the wasted heat is really a problem. Power efficiency is not critical for this application, as an electric motor will be drawing 10's of amps, compared to the few hundred mA for this module.
