i am using a flyback transformer circuit to keep the footprint small and cost efficient. Its been suggested to me to keep the frequency high so the transformer can remain small.
how is the frequency set in a flyback converter circuit?
Which components are different when transforming a load of 400mA or transforming a load of 5A? (i am using 5A, though most of what i see on Google is people looking to transform to 400mA for 30-60V DC)
is this something i can find load measurements on my components for, if so, which components measurements should be reviewed when changing the load capacity to a greater amperage?
this is my application .. 120V AC -> flyback transformer circuit -> 5V DC 5A power draw
the others i have seen are 30V DC -> flyback transformer circuit -> 5V DC 400mA power draw
the power draw is much greater in my circuit, i am looking to find what changes there are.
the flyback converter circuit i am designing is going to change AC to DC also. I think (don't know, looking for confirmation on) a typical flyback transformer changes DC to AC and then back again in it's typical application. So it does not matter whether it is AC or DC on its first input?
i am going to use a tool called WEBENCH - its available from Texas Instruments https://webench.ti.com/ . suggested to me by @user4578 on the post that lead to this Which buck converter can be used for 120 V AC to 5 V AC rated at 5 amps? - on that post it was decided to use an isolated transformer circuit to step down from 120V AC instead of the buck converter i had originally intended.
