I was looking at the construction of flyback transformers and found that there are two modes - continuous and discontinuous. I have related questions:
  1. Is the circuit design for continuous mode and discontinuous mode the same? As far as I have seen the continuous flyback have the same design and discontinuous but as the duty cycle increases from 50% or more the transformer isn't discharging much and hence, we have a continuous mode.
  2. Following the first point. Does that mean that a lower duty cycle or a buck effect will be a discontinuous mode since the core energy is completer utilized before the next pulse.
  3. Similarly, a boost effect will then be a continuous mode.
  4. Does the Mode depend on the load attached? Higher load means higher discharge and it behaves in discontinuous mode?
  5. In the continuous mode we shall have a higher risk of getting the core saturated due to the higher constant current.
Kindly help me if I am right in this relation between the CCM and DCM?? Also help me in figuring out the correct difference between the two in terms of circuit changes if any apart from the duty cycle.
  • \$\begingroup\$ There is no "buck or boost" but only buck effect when converting from higher voltage from AC main. DCM or CCM mode are automatically selected by the ic whether there is no load (or very little load like less than 100mA) or in normal load operation. But I forgot which one does what. I should read the ic datasheet again. \$\endgroup\$
    – Fredled
    Commented Nov 4, 2023 at 11:17
The terms "DCM" and "CCM" are general terms that apply to all power converters, and these refer to whether or not the inductor current remains non-zero throughout the switching cycle. If the current is at zero for a part of the cycle, then it is DCM; and CCM otherwise. The case where the current momentarily touches zero is called "BCM", "Boundary Conduction Mode" since it is the boundary case between DCM and CCM.
The case of the fly-back is a little bit special, and serves to illustrate an important point regarding coupled inductors (thanks to @Andy aka for reminding me in the comments). Let's assume we have a simple flyback with just two windings, a primary and a secondary. If we observe the current in the transformer primary winding, we see that it always goes to zero during the switching cycle regardless of whether the flyback is in CCM or DCM mode. So how do we determine if the flyback is operating in CCM or DCM? Well, that depends on what the current in the secondary winding is doing at the time the primary switch is turned on again at the start of the next cycle. If it is still conducting, then the flyback is in CCM; but if it has stopped conducting, then it is DCM. This leads us to make a more general statement about CCM vs DCM:
Consider one complete switching cycle of the converter. Now consider a plot of the energy stored in the magnetic field of the main magnetic component vs time over one complete cycle. If that plot shows a distinct period when energy is zero, then the converter is in DCM. If the plot energy is always non-zero, then we have CCM. The boundary between these two cases is BCM.
When considering whether a converter is in CCM or DCM, be aware of any coupled inductors - there are other types of converters apart from the flyback that use coupled inductors, and it can be confusing to determine if they operate in CCM or DCM.
There are already several posts on this website that will answer most if not all the questions you have. Below is a small sample, may I suggest reading these, then perhaps re-consider your questions if you need further insight.
Hope this helps.
CCM, DCM and BCM - Inductor?
Flyback converter DCM and CCM transition voltage?
CCM flyback or DCM flyback?
How to know if a flyback converter is working in CCM or DCM
    \$\begingroup\$ Fabio, more strictly speaking (I'm thinking specifically the flyback circuit), continuous conduction really means one of the windings is still carrying current. Or, put more generally, CCM really means that there is energy remaining in the core at the point when the switching cycle restarts. \$\endgroup\$
    Commented Oct 30, 2023 at 13:14
  • \$\begingroup\$ Yes, agreed, it is indeed the energy in the core, I forgot that the current in the primary goes to zero for the flyback in CCM (and DCM, of course), thanks & cheers. \$\endgroup\$ Commented Oct 30, 2023 at 22:05
  • \$\begingroup\$ @Andyaka Thanks again Andy for the reminder, I have updated my answer, hopefully it is clear now. Cheers. \$\endgroup\$ Commented Nov 4, 2023 at 10:33
