I am implementing the following oscillator circuitry on my breadboard:
I am using the LM324n op amp and a solderless breadboard. The oscillator is tuned at about 500KHz resonant frequency, but when I hook my scope's probes there is no signal present at the output. could this purely be because of the breadboard? (coupling/decoupling, capacitance between traces and ...) or is it a faulty IC, since i think this specific IC has been lying around since late 90's! but it seems to work fine when working as a normal inverting amplifer.
I also tried reducing the gain (before theoretically stopping the oscillation) to check if its the GBP value being exceeded, but to no avail.
any help would be greatly appreciated.
  • \$\begingroup\$ A single transistor properly designed will give more gain-bandwidth than a 741 at 500 kHz. \$\endgroup\$
    – glen_geek
    Commented Jul 27, 2020 at 11:54
  • \$\begingroup\$ LM324 and 500kHz are fundamentally incompatible. \$\endgroup\$
    – user16324
    Commented Jul 27, 2020 at 14:16
The LM324 has not got enough open loop bandwidth to sustain a gain of 3.3 at 500 kHz. Try running at a lower frequency to prove this. If you made the inductor 1000 uH you would get oscillation: -
And, if you made C1 = 10 nF (inductor still at 1000 uH) you would get a tad more amplitude: -
But see how the op-amps's slew rate limiting is converting this into a triangle wave. If you went even lower in frequency (L = 10000 uH and both capacitors at 100 nF) you will begin to see a sine wave evolving from the noise: -
But, because there is nothing in the circuit to limit gain (yes, you need a gain control system in a sinewave oscillator), the sinewave gets bigger and bigger until it hits the maximum output swing that the LM324 can muster. It's now a sort of square wave.
