To illustrate how flash memory works, I thought to build a primitive FGMOSFET and show that it stores a single bit of information (charged, uncharged).
It would require a high voltage to charge, it could be unreliable and leak current, but it would show the basic idea, and I could disconnect and reconnect it, and show with a multimeter that it remains charged or uncharged.
Is that viable?
How would I do it?
These FETs rely on tunneling.
To deposit charge into a bit, the insulation must be very thin, so under the stresses of high_voltage, the probability of electron movement becomes high/certain.
And afterward, with "normal" operating voltage, the probability of electron escaping becomes near zero, so the "bit" remains charged.
Thus you need to build a system with extremely thin insulation, that is of very high quality, very pure.
And with those skills, semiconductor fabs will want to hire you.
  • \$\begingroup\$ I was going to say it's easy- Start by building a semiconductor fab, pulling some pure silicon ingots, sawing into wafers, make a mask set, process the wafers, singulate, package, and done! \$\endgroup\$
    – John D
    Commented Aug 9, 2020 at 17:16
    \$\begingroup\$ What I had in mind is to make a thicker insulation, but to use much higher voltage to make electron escape (I might be talking nonsense, but that's what I had in mind). It wouldn't be usable, but it would demonstrate the technique. \$\endgroup\$ Commented Aug 9, 2020 at 18:03
  • \$\begingroup\$ @JohnD I seem to remember seeing silicon wafers for sale somewhere for only 3-digit prices. \$\endgroup\$ Commented Aug 10, 2020 at 19:07
  • \$\begingroup\$ @user253751 Sure, but that violates the DIY spirit of the question. \$\endgroup\$
    – John D
    Commented Aug 10, 2020 at 19:56
  • \$\begingroup\$ Making your own MOSFET on a silicion wafer you bought still counts as making your own MOSFET. \$\endgroup\$ Commented Aug 11, 2020 at 10:26
