ESP8285 IC QFN32 is a chip.
https://robu.in/product/esp8285-ic-qfn32-original/
What does 32 mean in QFN 32? If I have a part/ footprint having the name as QFN50P500X500X90-33N-D. Will it be different than QFN 32 ?
It means 32 "pins" or connnection points around the edge. OK, so a QFN package doesn't have pins - it has solder connections. There are 32 of them on the edges of the chip.
No. Not unless your layout system is being very, very confusing. A QFN50 package has a 5 mm x 10 mm body, while a QFN32 package has a 5 mm x 5 mm body. So labelling a footprint for a QFN32 part with a starting field of "QFN50" would be an appalling way for the footprints to be identified.
QFN-32-1EP_5x5mm_P0.5mm_EP3.45x3.45mm
. I need a 5mm x 5mm footprint. A small follow-up question please: From the name I guess the pitch is 0.5 mm? and whats that 3.45x3.45 stands for?
Commented
Aug 27, 2020 at 12:40
QFN32-PARTNUMBER
Lets break the footprint name to its parts:
This naming convention is specified in an IPC Standard (I don't remember which one).
32 is the number of pins on the package. QFN32 is a QFN (Quad Flat No Leads) package with 32 pins. See here
This is just the amount of pins on the IC. QFN32 will have 32 pins on the IC
Looking at the picture in your link:
You can see that there are 32 pins, hence the '32' after QFN. You will also notice the large pad in the center. Not all packages have this extra thermal pad, so always check the footprint on an IC before creating one in your preferred PCB design package. This thermal pad will usually have to be created as pin no. 33
Commented
Aug 27, 2020 at 12:41
32 is the number of perimeter pins.
Some parts may have a central ground or thermal pad, radio parts as you link especially. Where that needs to be electrically connected it becomes logically a "pin" too, and if particular PCB software cannot handle pin numbers that are not purely numeric, it would be pin 33.
