I have built this circuit but the LED lights even when I move it near DC not only AC.
Does it detect the frequency or the magnetic field?
It doesn't surprise me - the copper wire spiral and your hand are integral to make this work - if your hand is picking up AC electrical fields then the DC circuit is acting like a ground to the AC and enough AC voltage will appear across the base-emitter of the left transistor to operate it.
It detects an AC electric field and a higher frequency will be more effective up to a certain point.
With those three BC547 transistors arranged as they are, that circuit will probably do a pretty good imitation of an electrometer.
A simple electrometer looks like this:
From the above linked web page.
It reacts to electric fields. It can "see" batteries that are just standing there doing nothing.
They can also detect static charges, like an electrostatically charged wool sweater or blanket - or cat.
Being made of bipolar junction transistors (BJT) rather than a junction gate field effect transistor (JFET,) yours probabaly won't be as sensitive as the circuit above made from a JFET.
Your circuit is reacting to the electric fields, not specifically to AC.
If you bring this detector near a perfect DC source, but your hand is not being held perfectly steady, you are in effect creating an "AC" voltage. As you move closer & further from the DC electric field, the strength of the field changes, which is basically the same effect as if you were near an actual 'AC' source
