Yes exactly. Those symbols dont represent actual components they are just a "bus" symbol. All it means is every symbol that matches needs an electrical connection between them. It also implies what voltage those lines should be at constantly when powered on. Usually a voltage regulator will be somewhere in the schematic if its a complete schematic.
In the Li'l Gray OD schematic +9V is the external 9 volt power source. V+ is just wired up to the power source through 100 ohm resistor so its effectively also 9 volts. Not really sure why they did that, its generally bad practice. Vr probably stands for "voltage reference" and basically is just sitting at around 4.5 volts. Vr is basically used to bias the opamp in the schematic which is typical for an Opamp.
