We assume that the \$n\$ batteries have been connected in parallel, and the external resistor connecting the endpoints(terminals) of the parallel part.
\$n:=\$ number of the batteries.
\$r_i:=\$ith internal resistance of the ith battery.
\$E_i:=\$ith EMF of the ith battery.
\$I_i:=\$ith current which flows between the endpoints of the ith battery.
\$I:=\sum_{i}{I_i}\$ ;(The current which flows through the external resistor).
\$R:=\$external resitance.
My textbooks says that below equation is true.
\$R*I=r_i*I_i+E_i\$
I thought that the above equation is wrong and my below equation is true as applying Kirchhoff's law(potential drops).
\$R*I+r_i*I_i=E_i\$
Can anyone tell me what I have been missing or mistaking so that I can resolve the problem on my own.
  • \$\begingroup\$ I think you're right. Hopefully someone more certain will come along, but as far as I can see R*I should have the same polarity as ri+Ii. It looks like you need to also modify the formula to take multiple batteries in parallel into account, which is less simple \$\endgroup\$
    – K H
    Commented Jan 26, 2021 at 5:38
What you're missing is the sign convention.
You have written the ith current down as simply which flows between the endpoints of the ith battery.Sloppy thinking like this is bound to get you into trouble.
If we define positive current as that flowing down the page, then we get your textbook's equation.
If we define positive current as that flowing from the positive terminal of each battery (admittedly the more natural way to view it), then we get your equation.
Which is correct? Both are, once you've drawn a diagram or otherwise specified your current convention for each. The textbook's convention has the advantage that it's more self consistent. If you draw a normally styled schematic, then all current arrows point down.
People starting out in this type of analysis often get stressed over the current direction. A common question is 'but what if I choose the wrong direction for the current in this branch when I'm placing my +ve current definition arrow?' The answer is it doesn't matter. When you do the sums, the current will come out with whatever sign is correct for your arrow. If it's negative, then it's flowing the other way to your arrow.
It's for this reason the textbook uses the convention it does. Label the currents consistently, so that you don't have to think when placing the arrows. Consistency means that you're less likely to make an error when creating the Kirchoff loop equations.
Draw it out as a schematic, you'll see the subtle difference that they are talking about:
\$R∗I=ri∗Ii+Ei\$
The "\$ri∗Ii\$" is taking into account the internal series resistance of the battery. And it is a voltage drop. So the battery voltage minus its internal voltage drop is equal to the voltage across the external resistor.
