I have a circuit where I would like to replace standard 10A glass fuses with some resettable solution. I have looked into polyfuses:
https://lcsc.com/products/PTC-Resettable-Fuses_11042.html?q=poly%20fuse
It seems they don't produce these for larger amperages. Any suggestions? In size it needs to be around the same as the glass fuse or smaller.
Are these safe btw on the long run? Because let's say I have the device on a remote location if something gets shorted which plugged into it that should remain turned off. As I understand these polyfuses reset themselves I don't see that too safe as if it keeps turning back the device off which had the fault that might leads to fire and other issues.
