I have this wireless charger. I put the transmitter in a 3D printed enclosure and the receiver in another 3D printed enclosure. On top of the receiver, I've put 8x INR18650-30Q 3000mAh batteries.
I've done some experimenting and have ultimately decided that the batteries get hot when they are not connected to anything and the wireless charger is working.
Am I correct?
Is there a way to stop the heating?
Edit:
Am I correct? Yes, @John Doe answered that this kind of power transfer is used in induction cookers. This effect seems to cook my batteries while charging them.
Is there a way to stop the heating? I did some more experiments.
As @Neil_UK suggested, I added a copper sheet between the batteries and the wireless receiver coil.
In the above image, two batteries are on top of the receiver. One of them is coated with a copper sheet, while the other isn't. After a minute, the naked battery is hot, while the coated is barely warm.
I added a plastic separator of 10 mm between the coil and the battery pack of 10 batteries in the above image. The current is 0.347A. Almost twice the nominal of 0.158A.
I added a copper sheet inside the battery pack just below the batteries. The current dropped to 0.187A. Still above nominal. So I added another sheet and it dropped to 0.142A.
After 10 minutes of running the wireless charger and two copper sheets below the batteries, they didn't get hot. Thank you all for helping out.
