I am routing a PCB in Altium 21.
I cannot seem to figure out how to show component outlines and designators on the PCB.
As of now components only show the pads.
How do I enable the component outline and designators in the 2D PCB view?
  • \$\begingroup\$ Is it in single-layer mode? Shift-S one or more times. \$\endgroup\$ Jul 8, 2021 at 17:44
  • \$\begingroup\$ If cycling through Shift-S does not show the other layers, check that those other layers are visible within the Layers section of the View Configuration. \$\endgroup\$
    – gcr
    Jul 8, 2021 at 20:56
Hit Shift-S to make sure you are not in single layer mode. Then hit L and select the layers you want to see. (another way to get to it is through design->boardlayers and colors)
While in this mode you can choose standard views, create your own (with your own colors) or select which layers are visible.
