Can I just solder an SMD part directly on the through holes of the PCB?
The pitch of SMD matches the pitch of the through holes.
  • 6
    \$\begingroup\$ I have done this many times. I have salvaged many boards that did not have high bypass capacitor on the regulator input. They fit nicely between the pads and look clean when finished. \$\endgroup\$
    – Gil
    Commented Jul 18, 2021 at 21:16
    \$\begingroup\$ What is the part? Is it high power, or does it require cooling? \$\endgroup\$ Commented Jul 19, 2021 at 7:34
For DIY project, no problem.
If you manufactured a large quantity then you'd have to care about having a low number of defects which means taking care of all the details. But for one-off DIY projects, yolo.
Unless there's something you're not saying, like the SMD part is a power transistor or LDO that needs a copper plane for heat sinking, stuff like that.
