I am going to measure the electrical response (voltage drop vs current) of an electrical contact joint modeled as resistance 0.4 ohm in following figure. I made a prototype circuit to control the current through the electrical contact joint and measure the voltage drop. The schematics was attached, too. The MOSFETs IRL3103 are switched using gate driver IR2104. The inductor was made of ferrite core. The problem is high loss and high temperature in first MOSFET. How can I minimize the power loss in the first MOSFET?
The actual voltage is 5V and the measured current for 50% duty cycle is 6A. The inductor was not saturated in 6A.
