I have a transformer which converts 220 Vrms to 9 and 18 Vrms (measured with multimeter, with no load at secondary). Assuming that I'm the manufacturer, how should I determine its output current rating?
About the primary, I know that its DC resistance is 77.3 ohms, and when connected to 50 Hz 220 Vrms, it consumes 3.3 W (no load at secondary.)
As to the secondary, I know that the DC resistance values are about 3.5 and 7 ohm, and the diameter of the wire used is about 0.65 mm.
The weight of the transformer is about 650 grams.
