I have two big heatsinks with four power MOSFETs on each of them, I want to control the temperature of each heatsinks so that doesn't exceed 80℃ using two LM35 temperature sensors:
There's no MCU involved and using another op amp I'll pulldown the MOSFETs gates when the limit is reached, the error up to 1-2℃ is acceptable.
Is this a good way to combine two sensors readings using analog circuitry or is there a better approach?
