I'm working on MOSEFT logic and I've come across this inverter which uses an N-MOS and a P-MOS.
In case it matters one intended use of this is for very low current indicators and the other is in a 6A circuit that is 8bit PWM driven.
The function is clear to me but often I find that discrete components are left out of simple concept diagrams. Which leads to my questions.
Every circuit I've made with MOSFETs so far has had either a pullup or pulldown resistor to hold the gate. Is anything like that needed here?
If not, then what holds the gates?
Does this circuit depend on Vin being specifically high or low? What would happen if it was disconnected or at high-z?
Also, is Cout a decoupling capacitor?
