I have a very old windscreen motor attached to a rotisserie which I would like to run. I was told that I need a battery charger, but most of the ones I can find are "smart" ones. I have a 2A smart charger and it doesn't work, reading a bit more it seems I need 10A capacity to start the motor while 'stalled'.
My question is does the charger have to be one that can explicitly run 12V appliances? E.g.
https://www.projecta.com.au/battery-charger-products/12v-automatic-10a-7-stage-battery-charger
or, can I get this intelligent charger with 7 modes?
https://www.supercheapauto.com.au/p/sca-sca-12v-10-amp-7-stage-battery-charger/544706.html
I have no idea what the stages in the specifications quoted below are:
SCA 12V 10 Amp 7 Stage Battery Charger | |
Chemistry Types: | Standard Lead Acid / AGM / GEL / Calcium |
Stages: | 1: Primary Analysis (Desulphation) / 2: Soft Start / 3: Bulk Charge / 4: Absorption / 5: |
Voltage: | 12V |
Start Voltage: | 0 Volts |
Amperage: | 10A |
Protections: | Surge / Reverse Polarity / Overload / Short Circuit |
Suitability: | Batteries up to 1100CCA / 100AH |
Warranty: | 12 months |
