I have a 12v 14amp hour lithium ion battery. Connected to a dc-dc buck step down voltage regulator with a potentiometer. Then this is connected to a set of heated goggles.
I have the potentiometer set to output 9.8v, as I was hoping to make the battery last longer than a direct connection, as well as run the goggles on a lower heat setting (they get very hot).
However it seems as though the battery lasts less time. I expected to get 12 hours of run time and only got 5.
Will the step down regulator actually draw more power from the battery over time? What is the best way to supply 10v and preserve the battery for the longest period of time?
I took these measurements with my multimeter. Amps was in-line on the positive connection, and volts was measured with the circuit complete and metering off the positive and negative.
Battery Direct to Goggles: 1.13 Amps 12.75 Volts
DC-DC Buck Step down Regulator installed between battery and goggles:
Between Battery and Regulator: .74 Amps 13.06 Volts
Between Regulator and Goggles: .9 Amps 9.8 Volts
I don't understand how it would be more amps after the regulator vs. before?
In any case, is there a better way for me to reduce the draw on the battery and make it last longer?
