This question maybe general question, but I have my own case like below.
I'm planning to make solar cell phone charger.
I found 1 solar cell with this specification as follows:
Brand: Staryu
Type: Polycrystalline Solar Module
Model : Staryu-10w
Rated Maximum Power : 10wp
Voltage At Maximum Power : 17.5V
Current At Maximum Power : 0.571A
Open Circuit Current : 21V
Short Circuit Voltage : 0.64A
Dimensions : 354 x 251 x 18mm
Maximum system voltage : 1000V
Here I summaried properties (specification) that I'm sure I know its purpose.
- Max Power: 10WP (Watt-Peak)
- Max Voltage: 17.5V
- Max Current: 0.517A
We know common properties in average phone chargers are like these:
- Power: 10W
- Voltage: 5V
- Current: 2A
Since that solar cell voltage
and current
is not syncroun with charger properties, so I'm applying Power Formula
so that solar cell will syncroun with phone charger.
Because current is not able to regulate, so I will regulate the voltage one. With this basic formula, all I need to do is just reduce voltage to 5V
so that the current will increase to 2A
as same as phone charger with Zener or IC Voltage Regulator? (still a question).
P = I * V
10W = I * 5V
I = 2A
So especially for my case, should I use Zener Diode or Voltage Regulator IC in regulating Voltage?
What simple case that we should use zener diode or voltage regulator IC?
Note:
- Correct any statements or calculation that I made if I'm wrong.
syncroun
is not a word. \$\endgroup\$
