I am trying to optimize a thermal detection circuit. But there are several problems.
The circuit for detecting 85 Celcius temperature and then disabled a PWM IC. When the FB pin is below 0.5V, IC is disabled and it waits to unplug the cable from the AC line. Due to there are some components that draw some current, it prevents IC to wake up. For example, if I changed R1-10k and R2-1k, it can not start. The IC has an HV start-up pin and it feeds the IC capacitor(C2) from the HV pin. When the IC wake-up, it supplies from aux-winding.
Another problem is related to the comparator start-up. How can I guarantee that during the first stage(IC is a start-up from an HV pin), the non-inverting input is higher than inverting input? Because if the comparator output is low instantly causes almost zero volts at FB pin. Therefore, the IC can never startup. I think, if I put a 1uF capacitor to parallel with R3, I can boost up the voltage on R4 in a short time. Thus, maybe I can not allow that situation. But in a very short time, the capacitor will draw a very high current and this can be a disaster for a start-up.
Also, when the temperature rise and NTC impedance drops, it will draw more current at that time. Even, if I unplug the cable from the line, the circuit will draw a high current as well because the NTC is not cool enough. And it is very difficult to obtain a precise temperature detection with an 11.5V supply because self-heating of NTC.
Can anybody help me with how can I optimize that circuit?
IC datasheet: enter link description here
