6
I'm currently taking a course in Electrical fields and circuits and came across this example problem from the course book. I am having trouble figuring out how to solve it. Below you will find my attempt.
From the textbook about point-dipoles
An interesting result occurs if we take the dipole to be “very small.” Here we mean that the
dipole has a spatial size, l, that is negligible compared with the
distance r to the point P where the field of the dipole is observed.
Source
problem
My attempt:
I will be using the following formula to solve the sub-questions a-e. According to my textbook, the electric field due to a "point" dipole is given by $$\bar{E}(\bar{r})=k_{e}\left[\frac{(3\bar{r} \cdot \bar{p})\bar{r}}{r^5} - \frac{\bar{p}}{r^3}\right]. $$
a. Along the positive x-axis, $$\bar{r} = \text{unit vector }\hat{x}$$ $$\bar{p} = p_{0}\hat{y}$$ $$r=0.01 \text{ m}$$
$$ \bar{E}(\bar{r}) = k_{e}\left[\frac{(3\bar{x} \cdot \bar{p})\bar{x}}{r^5} - \frac{\bar{p}}{r^3}\right] = k_{e}\left[\frac{(3p_{0} \cdot \hat{x}\hat{y})\hat{x}}{r^5} - \frac{p_{0}\hat{y}}{r^3}\right] \stackrel{\hat{x}\hat{y}=0}{=} k_{e}\left[-\frac{10^{-15}}{0.01^3} \right] = -9\hat{y}\text{ N/C}.$$
So far, so good according to the key I have available. Our answers match up. Doing the same for c. yields the same result as above and also matches with the key.
Though, when I try to do the same process for b. and d. something goes wrong and I get a completely different answer than the key.
b. Along the positive y-axis, $$\bar{r} = \text{unit vector } \hat{y} $$ $$\bar{p} \text{ and } r \text{ are the same as before.}$$
$$ \bar{E}(\bar{r}) = k_{e}\left[\frac{(3\bar{y} \cdot \bar{p})\bar{y}}{r^5} - \frac{\bar{p}}{r^3}\right] = k_{e}\left[\frac{(3p_{0} \cdot \hat{y}\hat{y})\hat{y}}{r^5} - \frac{p_{0}\hat{y}}{r^3}\right] \stackrel{\hat{y}\hat{y}=1}{=} k_{e}\left[\frac{3p_{0}\hat{y}}{r^5} - \frac{p_{0}\hat{y}}{r^3}\right] = k_{e}\left(\frac{3p_{0}}{r^5} - \frac{p_{0}}{r^3}\right)\hat{y} = 269691\hat{y}\text{ N/C} $$
This is completely incorrect, the key says it should be $$18\hat{y}\text{ N/C}$$ and it's the same for d.. Where am I going wrong?
d. I've tried doing the same process above but with $$\bar{r} = cos(45^{\circ})\hat{x} + sin(45^{\circ})\hat{y}$$ but I end up with the incorrect answer.
EDIT 1:
I have been trying to figure out how the formula I am using above actually works by trying to derive it but I can't seem to do it. In the textbook the following drawing is presented and give a short explanation as to where the formula of the Electric Field Due to a Dipole comes from from which they then show the formula for Electric Field due to a "Point" Dipole.
Say we have a dipole and we want to know the electric field due to the dipole at some arbitrary point P around the dipole.
Drawing
The electric field due to a charge is given by
$$ \bar{E}(\bar{r}) = \frac{k_{e}Q}{R^2}\hat{R},\text{ where } \hat{R}=\frac{\bar{R}}{R} $$
The position vector from the origin to the point where we wish to know the field we define as
$$ \bar{r} = \bar{r}_{Q} + \bar{R}$$
Variable descriptions
The electric field due to the dipole at some point of interest from the dipole is given by the sum of the individual contributions from the charges, that is
$$ \bar{E}(\bar{r}) = \bar{E}_{+} + \bar{E}_{-} $$
The displacement vector for the positive charge according to above definitions is
$$ \bar{R} = \bar{r} + \bar{r}_{q_{+}} $$
and as such the electric field due to the positive charge is
$$ \bar{E}_{+}(\bar{r}) = \frac{k_{e}q_{+}}{R^2}\hat{R} = \frac{k_{e}q_{+}}{|\bar{R} - \bar{R}_{q_{+}}|^{3}}\bar{R} - d/2 $$
Note that: $$\bar{R}_{q_{+}} = d/2 $$
where d (depicted as l in figure) is the distance between the charges in the dipole.
For the negative charge we get basically the same but slightly different.
$$ \bar{E}_{+}(\bar{r}) = -\frac{k_{e}q_{+}}{R^2}\hat{R} = -\frac{k_{e}q_{+}}{|\bar{R} + \bar{R}_{q_{+}}|^{3}}\bar{R} + d/2 $$
The displacement vector from the negative charge to the point of interest is slightly different, we see a + instead of a - because it has to travel an extra d/2 distance to get to the origin and then to the point.
Now if we add these together we end up with
$$ \bar{E}(\bar{r}) = \frac{k_{e}q_{+}}{|\bar{R} - d/2|^{3}}\bar{R} - d/2 + \frac{k_{e}q_{+}}{|\bar{R} + d/2|^{3}}\bar{R} + d/2 $$
$$ \bar{E}(\bar{r}) = k_{e}q\left[ \frac{\bar{R} - d/2}{|\bar{R} - d/2|^{3}} - \frac{\bar{R} + d/2}{|\bar{R} + d/2|^{3}} \right] $$
Now supposedly according to the textbook
dipole has a spatial size, l, that is negligible compared with the distance r
to the point P where the field of the dipole is observed. The result is that
the field at P due to the point dipole at the origin is well-approximated
by:
$$ \bar{E}(\bar{r}) = k_{e}\left[ \frac{(3\bar{r} \cdot \bar{p})\bar{r}}{r^5} - \frac{\bar{p}}{r^3} \right] $$
which is the formula I am trying to use, but I have no idea how they got here. No deriving is done from their part.
How did they get the last formula???
EDIT 2: On request from @jonk I uploaded the following drawing of how I understand the situation as posed by sub-problem b.
sub-problem-b
    \$\begingroup\$ I'll need to refresh details in mind before I answer. But I do remember that the on-axis field is twice the perpendicular field, given a dipole moment and a distance that is far away when compared with the charge separation of the dipole. And if memory serves, \$\mid \vec{E}_\bot\!\!\mid\,=9\times10^9\frac{N\cdot m^2}{C^2}\cdot \frac{p}{r^3}\$, so I agree with your book about the magnitude of the answer for a and b. \$\endgroup\$
    – jonk
    Commented Apr 18, 2022 at 18:14
  • \$\begingroup\$ You should draw some diagrams, though, and add them to the question. It almost always helps to do that. Even though you may imagine that anyone reading your text will be able to assemble the same picture in their mind as you have in front of you, it's better to be concrete about it and remove any room for doubt. \$\endgroup\$
    – jonk
    Commented Apr 18, 2022 at 18:22
    \$\begingroup\$ @jonk I have made two edits to the post, one asking about the derivation of the formula I am trying to use and one to add a drawing of how I understand the situation as posed by sub-problem b. \$\endgroup\$
    – NoName123
    Commented Apr 18, 2022 at 19:47
    \$\begingroup\$ This is an excellent question with well-documented input, attempts at solutions, and your thinking process. High praise! \$\endgroup\$ Commented Apr 20, 2022 at 21:40
7
Overview
Note: I've added some Glowscript/VPython code to help illustrate the value of using software programming tools. We have so much available to us, provided by many contributors to whom we owe much. Learn well to use the gifts we've been handed by these wonderful people.
Here is what I imagine for the dipole of \$\left(1\times10^{-15}\: C\!\cdot\! m\right)\hat{y}\$. (This might be \$3\frac13\:\text{pC}\$ separated by \$300\:\mu\text{m}\$ to represent your dipole moment, for example.)
(I drew that with Microsoft Paint.)
The field at any point around the above dipole will be the superposition (sum) of the effects of both charges. So:
$$\begin{align*} \vec{E}&=\vec{E}_++\vec{E}_-\\\\&=\frac1{4\pi\epsilon_{_0}}\frac{q_+}{\mid\vec{r}_+\mid^2}\hat{r}_+ + \frac1{4\pi\epsilon_{_0}}\frac{q_-}{\mid\vec{r}_-\mid^2}\hat{r}_-\\\\&=k_e\left[\frac{q_+}{\mid\vec{r}_+\mid^2}\hat{r}_+ + \frac{q_-}{\mid\vec{r}_-\mid^2}\hat{r}_-\right], \text{where }k_e=\frac1{4\pi\epsilon_{_0}}\approx 9\times10^9\:\frac{N\cdot m^2}{C^2} \end{align*}$$
(More exactly, \$k_e\approx 8.98755179\times10^9\:\frac{N\cdot m^2}{C^2}\$)
It's pretty simple.
Python -- Learn to Use It
Before I dig into your specific questions, this is a good place to make a case for learning to use Python. It's just too handy to ignore.
Let's express the above knowledge in VPython (I'll be using GlowScript 3.1 VPython):
ke = 8.98755179e9   # eqivalent for 1/(4*pi*e0) in SI units.
# Dipole charge and separation.
q = 5e-12 / 1.5     # 3 1/3 pC
s = 300e-6          # 300 microns
# Dipole moment.
p = q * s
# Computes E-field for a charge, as seen from any given point around it.
def E( qm, qp ) : return def ( p ) : return ke * qm * norm(p-qp) / mag(p-qp)**2
# E-field functions for the positive and negative charges.
ep = E(  q, vector( 0,  s/2, 0 ) )
en = E( -q, vector( 0, -s/2, 0 ) )
print( "Dipole moment: ", p, "C m")
That prints out:
Dipole moment:  1e-15 C m
I added a little extra code above because I'll be using this code, later, and will need the extra bits then. You can check this out on your own by using this link.
Case (a)
I'd draw it up this way:
At a point \$10\:\text{cm}\$ along the positive x-axis, the magnitudes due to the two charges along \$\hat{x}\$ cancel out, leaving only that caused along \$\hat{y}\$, as shown above in the image. These residuals (are shown in their associated color and direction and they) will add together and point downward, according to the usual conventions. So pointing as \$-\hat{y}\$, or \$\langle 0,-1,0\rangle\$. That's my qualitative expectation.
\$\vec{r}_+=\langle x, 0, 0\rangle-\langle 0, \frac{s}2, 0\rangle=\langle x,-\frac{s}{2},0\rangle\$ and \$\vec{r}_-=\langle x, 0, 0\rangle-\langle 0, -\frac{s}2, 0\rangle=\langle x,\frac{s}{2},0\rangle\$.
\$\hat{r}_+=\frac{\vec{r}_+}{\mid \vec{r}_+\mid}=\frac{\langle x,\,-\frac{s}{2},\,0\rangle}{\sqrt{x^2+\left(-\frac{s}2\right)^2}}=\frac{\langle x,\,-\frac{s}{2},\,0\rangle}{\sqrt{x^2+\left(\frac{s}2\right)^2}}\$ and \$\hat{r}_-=\frac{\vec{r}_-}{\mid \vec{r}_-\mid}=\frac{\langle x,\,\frac{s}{2},\,0\rangle}{\sqrt{x^2+\left(\frac{s}2\right)^2}}\$.
Let's now prove a result:
$$\begin{align*} \vec{E}_\bot&=\vec{E}_++\vec{E}_- \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot\frac{q}{\left[x^2+\left(\frac{s}2\right)^2\right]}\cdot\frac{\langle x,-\frac{s}2,0\rangle}{\sqrt{x^2+\left(\frac{s}2\right)^2}} + \frac1{4\pi\epsilon_{_0}}\cdot\frac{-q}{\left[x^2+\left(\frac{s}2\right)^2\right]}\cdot\frac{\langle x,\frac{s}2,0\rangle}{\sqrt{x^2+\left(\frac{s}2\right)^2}} \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot\frac{q}{\left[x^2+\left(\frac{s}2\right)^2\right]^\frac32}\cdot\langle x-x,-\frac{s}2-\frac{s}2,0-0\rangle \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot\frac{q}{\left[x^2+\left(\frac{s}2\right)^2\right]^\frac32}\cdot\langle 0,-s,0\rangle \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot\frac{q s}{\left[x^2+\left(\frac{s}2\right)^2\right]^\frac32}\cdot\langle 0,-1,0\rangle \end{align*}$$
There is no information given about the separation \$s\$ of the charges. Only the dipole moment of \$p=q s\$ is given. So, the dipole approximation with \$r=x=10\:\text{cm}\$ leaves you only with:
$$\begin{align*} \mid \vec{E}_\bot\mid&=\left[\frac1{4\pi\epsilon_{_0}}\right]\cdot\frac{q s}{x^3}=\left[9\times10^9\frac{N\cdot m^2}{C^2}\right]\cdot \frac{p}{r^3} \end{align*}$$
And you computed the result correctly as \$9\:\frac{N}{C}\langle 0,-1,0\rangle\$ or \$-9\:\frac{N}{C}\langle 0,1,0\rangle\$.
Let's check back in with that GlowScript, again. Adding the following code:
# Magnitude of distance from dipole.
r = 10e-3         # 1 cm
# Perpendicular position:
pp = r * vector( 1, 0, 0 )
# Net field.
eppnet = ep( pp ) + en( pp )
print( "Perpendicular: ", mag( eppnet ), "N/C", norm( eppnet ) )
We now get:
Perpendicular:  8.98452 N/C < 0, -1, 0 >
Not bad. Easy to use and understand, too.
Case (b)
At a point \$10\:\text{cm}\$ along the positive y-axis, the magnitudes due to the two charges along \$\hat{x}\$ are zero and those along \$\hat{y}\$ are shown in the image. (One is larger in magnitude than the other.)
\$\vec{r}_+=\langle 0, y, 0\rangle-\langle 0, \frac{s}2, 0\rangle=\langle 0,y-\frac{s}{2},0\rangle\$ and \$\vec{r}_-=\langle 0, y, 0\rangle-\langle 0, -\frac{s}2, 0\rangle=\langle 0,y+\frac{s}{2},0\rangle\$.
\$\hat{r}_+=\frac{\vec{r}_+}{\mid \vec{r}_+\mid}=\frac{\langle 0,\,y-\frac{s}{2},\,0\rangle}{\sqrt{0^2+\left(y-\frac{s}{2}\right)^2}}=\langle 0,\,1,\,0\rangle\$ and \$\hat{r}_-=\frac{\vec{r}_-}{\mid \vec{r}_-\mid}=\frac{\langle 0,\,y+\frac{s}{2},\,0\rangle}{\sqrt{0^2+\left(y+\frac{s}{2}\right)^2}}=\langle 0,\,1,\,0\rangle\$.
Let's again prove a result:
$$\begin{align*} \vec{E}_\text{on axis}&=\vec{E}_++\vec{E}_- \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot\frac{q}{\left[\left(y-\frac{s}2\right)^2\right]}\cdot\langle 0,1,0\rangle + \frac1{4\pi\epsilon_{_0}}\cdot\frac{-q}{\left[\left(y+\frac{s}2\right)^2\right]}\cdot\langle 0,1,0\rangle \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot q\left[\frac{1}{\left[\left(y-\frac{s}2\right)^2\right]} + \frac{-1}{\left[\left(y+\frac{s}2\right)^2\right]}\right]\cdot\langle 0,1,0\rangle \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot q\left[\frac{\left(y+\frac{s}2\right)^2-\left(y-\frac{s}2\right)^2}{\left[\left(y-\frac{s}2\right)^2\right]\left[\left(y+\frac{s}2\right)^2\right]}\right]\cdot\langle 0,1,0\rangle \\\\ &=\frac1{4\pi\epsilon_{_0}}\cdot\left[\frac{2 q s y}{\left[\left(y-\frac{s}2\right)^2\right]\left[\left(y+\frac{s}2\right)^2\right]}\right]\cdot\langle 0,1,0\rangle \end{align*}$$
Again, there is no information given about the separation \$s\$ of the charges. Only the dipole moment of \$p=q s\$ is given. So, the dipole approximation with \$r=y=10\:\text{cm}\$ leaves you only with:
$$\begin{align*} \mid \vec{E}_\text{on axis}\mid&=\left[\frac1{4\pi\epsilon_{_0}}\right]\cdot\frac{2 q s y}{y^4}=\left[9\times10^9\frac{N\cdot m^2}{C^2}\right]\cdot \frac{2 p}{r^3} \end{align*}$$
Which should be twice as large, in magnitude, as for case (a).
But in this case the sign is positive.
Let's check back in with GlowScript. Adding the following code:
# On-axis position.
onaxisp = r * vector( 0, 1, 0 )
# Net field, again.
eonaxisnet = ep( onaxisp ) + en( onaxisp )
print( "On axis: ", mag( eonaxisnet ), "N/C", norm( eonaxisnet )
We now get:
On axis:  17.9832 N/C < 0, 1, 0 >
Again, not bad.
Case (e)
I thought I'd add a little bit towards this case:
$$ \begin{align*} \begin{array}{rl} {\vec{r}_+} &= \vphantom{\langle \frac{r}{\sqrt{2}}, \frac{r}{\sqrt{2}}, 0\rangle-\langle 0, \frac{s}2, 0\rangle}\\\\ &= \vphantom{\langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}-\frac{s}{2},0\rangle}\\\\ {\hat{r}_+} &= \vphantom{\frac{\vec{r}_+}{\mid \vec{r}_+\mid}}\\\\ &= \vphantom{\frac{\langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}-\frac{s}{2},0\rangle}{\sqrt{\left(\frac{r}{\sqrt{2}}\right)^2+\left(\frac{r}{\sqrt{2}}-\frac{s}{2}\right)^2}}} \end{array} && { \begin{array}{l} \langle \frac{r}{\sqrt{2}}, \frac{r}{\sqrt{2}}, 0\rangle-\langle 0, \frac{s}2, 0\rangle\\\\ \langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}-\frac{s}{2},0\rangle\\\\ \frac{\vec{r}_+}{\mid \vec{r}_+\mid}\\\\ \frac{\langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}-\frac{s}{2},0\rangle}{\sqrt{\left(\frac{r}{\sqrt{2}}\right)^2+\left(\frac{r}{\sqrt{2}}-\frac{s}{2}\right)^2}} \end{array} } &&&& \begin{array}{rl} {\vec{r}_-} &= \vphantom{\langle \frac{r}{\sqrt{2}}, \frac{r}{\sqrt{2}}, 0\rangle-\langle 0, -\frac{s}2, 0\rangle}\\\\ &= \vphantom{\langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}+\frac{s}{2},0\rangle}\\\\ {\hat{r}_-} &= \vphantom{\frac{\vec{r}_-}{\mid \vec{r}_-\mid}}\\\\ &= \vphantom{\frac{\langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}+\frac{s}{2},0\rangle}{\sqrt{\left(\frac{r}{\sqrt{2}}\right)^2+\left(\frac{r}{\sqrt{2}}+\frac{s}{2}\right)^2}}} \end{array} & { \begin{array}{l} \langle \frac{r}{\sqrt{2}}, \frac{r}{\sqrt{2}}, 0\rangle-\langle 0, -\frac{s}2, 0\rangle\\\\ \langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}+\frac{s}{2},0\rangle\\\\ \frac{\vec{r}_-}{\mid \vec{r}_-\mid}\\\\ \frac{\langle \frac{r}{\sqrt{2}},\frac{r}{\sqrt{2}}+\frac{s}{2},0\rangle}{\sqrt{\left(\frac{r}{\sqrt{2}}\right)^2+\left(\frac{r}{\sqrt{2}}+\frac{s}{2}\right)^2}} \end{array} } \end{align*} $$
Once again,
$$\begin{align*} \vec{E}_{45^\circ}&=\vec{E}_++\vec{E}_-=\frac1{4\pi\epsilon_{_0}}\frac{q_+}{\mid\vec{r}_+\mid^2}\hat{r}_+ + \frac1{4\pi\epsilon_{_0}}\frac{q_-}{\mid\vec{r}_-\mid^2}\hat{r}_- \end{align*}$$
If you follow through, you may also find (for \$r\gg s\$): \$\vec{E}_{45^\circ}=\left[\frac1{4\pi\epsilon_{_0}}\right]\cdot \frac{p}{r^3}\cdot\langle \frac32,\frac12,0\rangle\$. So I get \$\approx 14.23\:\frac{N}{C}\:\angle 18.435^\circ\$.
Returning to Glowscript and adding this code:
# 45-degree, quadrant 1 position.
ap = r * vector( cos( pi/4 ), sin( pi/4 ), 0 )
# Net field, yet again.
eanet = ep( ap ) + en( ap )
print( "45 degree: ", mag( eanet ), "N/C", norm( eanet ) )
I get:
45 degree:  14.2107 N/C < 0.948762, 0.315993, 0 >
(Note that it computes a normal that has a hypotenuse of 1. I had to do that, too. But didn't want to write the expression that way, preferring to use an unnormalized vector, instead. The magnitude results are the same, either way.)
I also did a quick visual simulation using Glowscript (see code here, for example.) Using \$3\frac13\:\text{pC}\$, separated by \$300\:\mu\text{m}\$, made the dipole pretty small in the image:
(That result was achieved using \$9\times 10^9\$ rounded figure and not the more exact figure used in earlier simulations.)
But it gets the point across. I also performed a computation using Python and displayed the value at the bottom. (The arrow with the little red 'star' at its tip is this vector at \$45^\circ\$.) Matches with my expectations, above.
Summary
That's as far as I want to go, here. I feel it is sufficient to show how to reach case (b) and that you should be able to translate the above into the context of your own book (which I do not have), in order to produce the remaining results.
Finally, with VPython, the above could have been done slightly differently:
class StaticCharge:
  def __init__( self, charge, position ):
    self.charge = charge
    self.position = position
  def q( self ) : return self.charge
  def pos( self ) : return self.position
  # Coulomb’s law (stationary charges -- breaks down in relativistic cases.)
  def E( self, pos ) : return ke * self.charge / mag2(pos-self.position) * hat(pos-self.position)
class Dipole:
  def __init__( self, charge, separation, axis ):
    self.axis = axis
    self.separation = separation
    self.moment = charge * separation
    self.positive = StaticCharge( charge, separation/2 * axis )
    self.negative = StaticCharge( -charge, -separation/2 * axis )
  def posp( self ) : return self.positive.pos()
  def posn( self ) : return self.negative.pos()
  def sep( self ) : return self.separation
  def p( self ) : return self.moment
  def E( self, pos ) : return self.positive.E( pos ) + self.negative.E( pos )
  def D( self, pos ) :
    efield = self.E( pos )
    return f"{mag( efield )} N/C {hat( efield )}"
# Input: dipole moment and charge.
p = 1e-15           # dipole momentum
q = 10e-12 / 3      # 3 1/3 pC
# Input: radial distance.
r = 10e-3           # 1 cm
# My dipole: has charge q, separation p/q, and aligned on the y-axis.
mydipole = Dipole( q, p/q, vector( 0, 1, 0 ) )
# Three points of interest around the dipole.
perpendicular = r * vector( 1, 0, 0 )
onaxis = r * vector( 0, 1, 0 )
fortyfive = r * vector( cos( pi/4 ), sin( pi/4 ), 0 )
# Display the E-field at these three points around the dipole.
print( "Perpendicular: ", mydipole.D( perpendicular ) )
print( "On axis: ", mydipole.D( onaxis ) )
print( "45 degrees: ", mydipole.D( fortyfive ) )
# Create graphical balls for the dipole.
ballp = sphere( pos = mydipole.posp(), radius = mydipole.sep()/2, color = color.red )
balln = sphere( pos = mydipole.posn(), radius = -mydipole.sep()/2, color = color.cyan )
# Perform a loop generating 64 vectors in a circle around the dipole.
N = 64
theta = 0
dtheta = 2*pi / N
while theta < 2*pi:
  ro = r * vector( cos(theta), sin(theta), 0 )
  arrow( pos = ro, axis = 2e-4*mydipole.E( ro ), color = color.green )
  theta = theta + dtheta
For the above code see here. This outputs:
Pretty nice and easy.
An Added Diversion
The above results ignore the z-axis, so it's really a 2D situation being displayed. However, in 3D the results are symmetrical about the z-axis. Use your imagination for that.
But given the above Python code, it might be fun to investigate a highly simplified capacitor approximated by a simple row of dipoles to see what happens in 2D. The code is here and the results are:
This is not an accurate reflection of how charges distribute themselves on a parallel plate capacitor, as there must be an increasing charge density when approaching the edges, and the above model doesn't accommodate this fact. Instead, it spreads them out completely evenly. Also, the plates are infinitely thin in this example and in reality they are not. (Finite thickness conducting plates must have charge on their outer faces because the line integral of the electrostatic field around any closed path must vanish.) But it is still interesting.
An exaggerated but also illustrative example would be more like this:
For more information on this topic, see "Electric field outside a parallel plate capacitor," by G. W. Parker, 2002, American Journal of Physics, 70(5), 502-507, doi:10.1119/1.1463738.
The point I'd also like to emphasize is the power of using VPython and Glowscript Trinket (tikz stuff) for physics modeling.
In fact, there's a book on the topic of Python generally for physics called, "Essential Python for the Physicist," by Giovanni Moruzzi, 2020.
\$\bar{E}(\bar{r}) = k_{e}\left[ \frac{(3\bar{r} \cdot \bar{p})\bar{r}}{r^5} - \frac{\bar{p}}{r^3} \right]\$
Do a 1st order expansion.
Given the E field from a charge at the origin is:
\$\bar{E}(\bar{R}) = Q\frac{\bar{R}}{4\pi \epsilon_0 R^3} \$
and the field from a charge located with a displacement \$\bar{d}\$ from the origin is:
\$\bar{E}(\bar{R}) = Q\frac{\bar{R}-\bar{d}}{4\pi \epsilon_0 |\bar{R} - \bar{d}|^3} \$
we approximate this using
\$|\bar{R}-\bar{d}|^2 = (\bar{R}-\bar{d}) \cdot (\bar{R}-\bar{d}) = R^2 - 2\bar{R}\cdot\bar{d} + d^2\approx R^2\left( 1 - \frac{2\bar{R}\cdot\bar{d}}{R^2}\right)\$
for the case \$|\bar{d}| << |\bar{R}|\$
Use this, plus the 1st order approximation for
\$\frac{1}{(1+\delta)^\alpha} \approx 1 - \alpha \delta\$
for \$|\delta| << 1\$
and you should be able to derive the formula
