So I am using this AND gate which has an open drain output. I am trying to determine how many loads that I can place on this output. I see in the datasheet, that the Iol is over 1mA, but I am unsure as to whether it can drive the loads when in high Z.
So if the input loads have a input current of .5uA, what will supply this current to these loads. Is it the open drain output?
Thanks!
