Motivation
I know that a similar question has been asked before (control power to water heater,) but prices and technology have changed, and my situation is slightly different so I am asking again.
My situation is that I have about 5kW peak solar panels, about 11kWh Li batteries and an 8kW inverter (Deye.) I am prepared to add a couple more panels if necessary.
Our electricity supply is intermittent (South Africa) and there is currently no feed-in tariff for small home systems so I have no motivation to supply power back to the grid. On sunny days, my battery (which I let discharge in the night) is usually charged up by noon, and then the rest of the solar power during the day goes to waste. I would like to add an intelligent controller to save this excess energy as heat in my hot water system.
My initial thoughts were a Raspberry Pi/Arduino based system that interrogated the inverter, determined the load, and PV generation, then (based on the currently set control algorithm) would funnel excess power to a hot water system. My current element is about 3kW, 250V.
I am a semi-retired scientist/software developer, but not an electronic engineer. I have programmed Arduinos before for semi real time applications.
I was wondering about using a SSR capable of switching 15 or 25 amperes at 250V, and setting it up to act like a trailing edge (or leading edge) dimmer, i.e. wave form as shown below:
Proposed solution
With an Arduino (or Raspberry Pi) it should be easy enough to switch within millisecond accuracy to get the required percentage of the full element power.
Obviously we would also have a thermostat in the loop (either being intelligently read by the control system, or just the old simple type on/off thermostat as used in normal electrical heaters.)
Questions
- Is this a practical idea?
- Would it be better to just switch off a whole cycle (or half cycle) at a time?
- Will the SSR be able to switch fast enough? (The ones I have seen are 0.1msec switch on time and ~ 11msec switch off time.) Presumably you get faster switching ones.
- Could this damage the inverter, or place some kind of weird inductance/power factor/ (name your own bad thing here) load on the inverter?
- The SSRs I have seen for sale mention that they have a TRIAC inside (with built in snubber on the output). Is this good or would it be better to use something else (MOSFET maybe)?
I know that one needs adequate heat sinks, wiring thicknesses etc. for this kind of power, and would get help from electrical design people/ colleagues if I decided to go ahead with this.
