I have been trying to understand the datasheet of solid state relays from different manufacturers and I was not much familiar with solid state relays. A confusion arose when I came to see the control voltage or input voltage mentioned as VAC/VDC.
You can see in the snap taken from a datasheet of Sensata-crydom attached above, control voltage given as "208-265 VAC", "18-30 VDC", "36-35 VAC/VDC". To my knowledge I understand if given "VAC" it is an ac voltage input and if given "VDC" then it is dc input voltage. But what in the case of VAC/VDC?
I have also came across some relays with both ac and dc control but they mentioned different VAC and VDC input voltage
here in this snap under CWU the value is "20-48 VDC/ 20-280 VAC"
So what is the difference between this case and that VAC/VDC case?
If both are same , can we consider both ac and dc voltage range are same in VAC/VDC case?
Or does VAC, VDC have any other meaning than I understood?
