I bought a used electric utility vehicle that normally uses eight lead acid 6 V 260 Ah batteries wired in series. The utility vehicle instead came with four 12 V 105 Ah batteries wired in series. The charger included is a 48 V charger for 140-270 Ah. If I charge the 48 V 105 Ah series of batteries with this 140-270 Ah charger, will they explode or have other ill effects on the batteries, the charger, or the surrounding environment?
The batteries I have are MK Battery 8A31DT https://www.ecodirect.com/MK-Battery-8A31DT-DEKA-12-Volt-104-AH-Battery-p/mk-battery-8a31dt-sealed-agm.htm
The batteries normally used I think are Trojan T145 https://www.trojanbattery.com/product/t-145/
The charger is a Lester Electric Lestronic II Automatic battery charger (can't find an accurate link)
Thanks for any help!
