I would like to supply a 12 VDC, 3500 RPM permanent-magnet motor with a 24 V battery using a 12 V voltage regulator.
The motor will be coupled to a 220 V, 1.2 kW, 50 Hz, 1450 RPM generator. The power produced by the generator will be used to recharge the battery.
I want to simulate all this in software and see how much time it will take for this system to stop and how efficient it will be.
Apart from MATLAB, in which other electrical software can I model and simulate a motor/generator set and analyze its behavior?
