I'm looking at generating electrical energy from a mechanical input being used to rotate the shaft of a Permanent magnet DC motor. However, i'm a bit stuck with selecting the right motor and battery to store the energy in(and everything else needed between)
My average mechanical input to the motor will have a power of approximately 200W, and the shaft RPM would be in the range of 500-1500. However, the RPM will be prone to fluctuation within this range (It's an ergometer so RPM and Torque will vary throughout each individual stroke)
I plan to store the produced electrical power in a battery. However, i'm not very clued up at all with the electronics side of things.
My first question is: Is it best to use a Permanent magnet DC motor as a generator, or an Alternator? I'm not quite clear which is best in this situation and why. Since I will be storing the energy in a battery, i have been going on the assumption that a DC motor is best?
Secondly: What other components are needed in the circuit between the motor and the battery? And what kind of efficiency can i expect from each component (Very approximate?)? IE if i put 200W in, how much can i expect to actually reach the battery?
Finally: Is it possible to charge a battery with an unstable voltage? or would this present problems and some method of controlling the voltage would be needed?
Thanks!
