What is the best way to add a volume control POT to this circuit? It is based on an LM4871, and the datasheet is located here: datasheet
1 Answer
Replace Rf with a 20k pot set up as a variable resistor. The output will be proportional to the resistance.
\$\begingroup\$ Thank you! This worked perfectly! \$\endgroup\$– wryanCommented Feb 12, 2023 at 5:13
