Can you please advice what is the symbol in red in following wiring diagram.
    \$\begingroup\$ "Burner Reset" is almost certainly a thermal limit switch with manual reset. It will cut out if its design temperature is exceeded. \$\endgroup\$
    – Dave Tweed
    Commented Dec 15, 2022 at 1:16
  • \$\begingroup\$ It looks like an external reset switch that is poorly documented. ferroli.com/media/1492008768.pdf \$\endgroup\$
    – D.A.S.
    Commented Dec 15, 2022 at 2:04
It looks like an external reset switch that is poorly documented. Yet defined as BURNER RESET. This is a Ferroli wood pellet burner furnace. https://www.ferroli.com/media/149200876/8.pdf I assume it is used after fault maintenance is repaired. Call them and ask. 800 596040 Tel: +39 045 6139411 Fax: +39 045 6100933
[email protected] [email protected]
