symbol
I'm student trying to make a project, but I don't know what this symbol means. That is full diagram diagram
Answer is: the symbol is the electromagnetic gripper
  • \$\begingroup\$ You might help us telling what drawing that is. Some device perhaps? \$\endgroup\$
    – Justme
    Commented Jan 8, 2023 at 20:20
  • 4
    \$\begingroup\$ If it makes you feel better I’ve been doing this professionally for 20 years and well before that into my childhood and I have no freakin idea what that is. \$\endgroup\$
    – Bryan
    Commented Jan 8, 2023 at 20:33
    \$\begingroup\$ what does switch SA3 do on the machine? ... the component in question may be a motor of some type ... SA3 selects a direction \$\endgroup\$
    – jsotola
    Commented Jan 8, 2023 at 20:37
    \$\begingroup\$ then the symbol is the electromagnetic gripper \$\endgroup\$
    – jsotola
    Commented Jan 8, 2023 at 20:47
    \$\begingroup\$ Rather than putting the answer in the comments and/or the questions, please feel free to write an actual answer to your question. This is a not-uncommon practice here when you ask, then figure out the answer independently. \$\endgroup\$
    – TimWescott
    Commented Jan 8, 2023 at 21:08
  • We can see from the label on TC terminals 4 and 6 that the device is fed from a 123 V, 150 VA winding.
  • The supply is rectified by VC. (Notice that the diode is pointing to an AC terminal which is incorrect so we don't know whether 10 or 12 is DC+.)
  • SA3 is a polarity changing switch for YH but notice that when SA3 is to the right the device receives full current but when to the left current will be limited by R.
  • As suggested in the comments this is probably the electromagnetic gipper.
  • My guess is that full current is used to pick things up and that a small reverse current is used to remove any residual magnetism left in the iron core when the magnet is switched off.
The symbol is strange and probably made up by whoever drew the schematic. I think it is saying that if + is applied to 16 then it behaves as a solenoid but if + is applied to 18 it will not behave as a solenoid, hence the X.
If my thinking is correct then SA3 to the right should connect + to 16 so 10 is connected to the VC + terminal.
  • \$\begingroup\$ I think you're right about the symbol being made up. A lot of new applications need something to represent a component that did not exist when the standard symbol set was created. \$\endgroup\$
    – SteveSh
    Commented Jan 8, 2023 at 21:30
    \$\begingroup\$ I think the X simply represents the actual device('s) function, while the coil symbol means it's a solenoid in either direction. Like you said, the switch changes direction of current, apparently to pick up and drop things off, and the current (or speed) is reduced in one direction. The ground symbol seems confusing at first, but it is most likely just a grounding connection for the metallic casing or the instrument/tool itself, to prevent either shock or leakage currents flowing from the gripper. \$\endgroup\$ Commented Jan 8, 2023 at 23:03
  • \$\begingroup\$ You probably mean something that grips rather than a role where Ronald Reagan portrayed a Notre Dame football coach. \$\endgroup\$
    – stretch
    Commented Jan 9, 2023 at 4:21
