You straight-forwardly state what the IC is inside your post - a 5A SMPS. Were you trying to find a pin out? Based on the fact that you found a similar package on two different ICs with different P/N that might point to the fact that it's a common footprint so you should theoretically be able to use the DS you found to find out pin-out.
In any case, you can still find the pin out easily by simply taking a DMM and short testing each pin to see which pins are connected to VDD, GND, near by components, etc. Let me know if you want me to elaborate.
Maybe you can update with a pic of the exact IC you're trying to find. Seeing the surrounding components for that IC would help. Also, if you can mention what the board does. I used to do competitive analysis all the time on PCBs and would have to figure out the exact info you're looking for.
