I want to do a simulation of fixed-service microwave links and I want to know how antenna heights above ground level (AGL) are determined on the receiving side.
For instance, if the transmitter antenna AGL height is 50 meters, then at a particular receiving location, will the receiver antenna AGL be such that, 1) based on the terrain elevation at the receiving location and 2) the tilt of the transmitter antenna, a visual line of sight between the transmitter antenna and the receiver antenna gets created?
That is to say, to compute a receiving side antenna AGL, should I look at the terrain elevation at the receiving location, the tilt of the transmitter antenna, and the transmitter-receiver distance (with earth curvature: the great circle distance would be selected as distance) to choose the receiver antenna AGL to create a visual line of sight geometrically?
