I am trying to write keypad (4*4) scan VHDL code for my DE10-lite board. In order to avoid floating signal for the input, I need pull up resistors.
There is an example I found from YouTube
However, the keypad only has 8 pins. How can I connect Vcc with pull up resistors to it?
... why do you sayonly
? ... the schematic diagram shows 7 pins ... your keypad has more pins than the schematic \$\endgroup\$
