Before this I'm launching my modified version of LoRaWAN_End_Node firmware, but my Nucleo Board keeps restarting and heating up so I unplugged the USB cable. When I tried to connect my board back I get a FAILS.txt
file with the following content
The interface firmware FAILED to reset/halt the target MCU
I tried to connect my MCU to the STM32Cube Programmer with under reset configuration and trying all reset mode configuration but got no luck.
Other things that I've tried:
- Disconnect JP1
- Connecting while pushing the reset button
- Doing point 1 and 2 at the same time
And still got no luck.
UPDATE #1
- Replugged the JP1 jumper and the heating issue is back (The MCU isn't completely dead, I guess (?))
- It is a Nucleo Board so it should be using an official ST-LINK
