I need to interface SD Card using SPI communication in stm32f103c8. First i to store the temprature value in every one seconds in sd card. It work well after that i try to store temperature value in that i need to erase the previous data and store the new temperature data. I have done the code but i only erase the data and it did not store the last updated temperature value please let me know where it went wrong.
my code.
#include "main.h"
#include "fatfs.h"
#include "math.h"
#include "fatfs_sd.h"
#include "string.h"
#include "stm32f1xx_hal.h"
#include "stdio.h"
#include "ssd1306.h"
#include "fonts.h"
#define CMD32 32
#define CMD33 33
FATFS fs;
FATFS *pfs;
FIL fil;
FRESULT fresult;
FILINFO fno;
uint8_t erase_cmd[6]={0x20, 0x00, 0x00, 0x00, 0x00, 0x95};
uint8_t status;
uint8_t SD_tx_buf[6];
uint8_t SD_rx_buf[6];
uint16_t adc_buf[100];
char buffer[100];
UINT br,bw;
FRESULT open_append(FIL* fp, const char* path); // object file create, file name to open
fresult = f_open(fp, path, FA_WRITE | FA_READ | FA_OPEN_ALWAYS); // new file create
if(fresult==0)
fresult= f_lseek(fp, f_size(fp)); // seek to end of the file to append data
if(fresult !=0)
f_close(fp);
return fresult;
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_ADC1_Init();
MX_I2C1_Init();
MX_RTC_Init();
MX_SPI1_Init();
MX_TIM1_Init();
MX_USART1_UART_Init();
MX_FATFS_Init();
set_time(); // time set function
fresult= disk_initialize(0); //initialize sd card **** SD Card Create File ****
fresult= f_mount(&fs, (TCHAR const*)arr,0);
if(fresult != FR_OK)
return fresult;
fresult= f_open(&fil, "Temp_Read1.txt", FA_OPEN_ALWAYS); //create text file
fresult= f_mount(&fs, (TCHAR const*)arr, 0);
fresult= open_append(&fil, "Temp_Read1.txt");
if(fresult == FR_OK)
f_puts("time\t Temp\n", &fil);
f_close(&fil);
// NVIC_SystemReset(); // INTERNALLY_RESET
for(i=0; i<100; i++)
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_RESET); /********Erase_cmd******** ****Working****/
HAL_SPI_Transmit(&hspi1, erase_cmd, sizeof(erase_cmd), HAL_MAX_DELAY);
HAL_SPI_Receive(&hspi1, &status, 1, HAL_MAX_DELAY);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_SET); HAL_Delay(10);
while (1)
HAL_RTC_GetTime(&hrtc, &sTime, RTC_FORMAT_BIN);
HAL_RTC_GetDate(&hrtc, &sDate, RTC_FORMAT_BIN); // RTC_TIME
hours= sTime.Hours;
mins= sTime.Minutes;
sec = sTime.Seconds;
ADC_sense();
sprintf(buff, "%d:%d:%d\t T1=%d, T1=%d, T1=%d, T1=%d, T1=%d\n", hours,mins,sec, temp1,temp2,temp3,temp4,temp5); // values stored in SD card
f_mount(&fs, (TCHAR const*)arr, 0); //mount sd drive **** SD Card Read Condition ****
// if(sec==59) // one min once temp data store
// count_p++; i++;
f_puts(buff, &fil); // values stored at SD card
f_close(&fil);
while(1){ };
f_open
and similar calls are appropriate and if you want to erase stuff then usef_unlink
to delete the file. You only use something like CMD32 if you're using the SD card as "raw" memory because doing that will destroy the filesystem (and you'll need to reformat it to be able to write files again). \$\endgroup\$
