I'm using this Nucleo board but unfortunately after I programmed it I have attached it to a base PCB in such a way that I can't access its USB port anymore. If I want to make an update and access its USB port I have to de-solder the entire board.
I have access to an ST-LINK-V3 but I have never used it.
Is it possible to program the Nucleo 32 by using the ST-LINK and its pins (not the USB port)?
